idle problem????
Old Feb 18, 2005 | 11:27 AM
moogotzskillz's Avatar
moogotzskillz
Default idle problem????
i got a 94 accord ex, with the VTEC 2.2L SOHC.. and when im on a light or stopin my idle goes up and down , u could hear it, it gotes from .5 rpm,. to 1.8 rpm.... some one told me tis a SENSOR, but i dont know which on if u could tell me if yea know,
THANX"s
MoE~~~
Old Feb 18, 2005 | 12:37 PM
JL95AccorD's Avatar
JL95AccorD
o2 sensor
Old Feb 18, 2005 | 12:49 PM
moogotzskillz
which one??? the one on the header or the one behind teh catalatic converter???? and why does it do that, is it from the gas or they intend to go out like that???
THANX
Old Feb 18, 2005 | 12:54 PM
JL95AccorD's Avatar
JL95AccorD
uummmm... both? I'm not sure, but I know that the o2 sensor can make the car act that way. Are you getting a CEL? You can always check them both with a volt meter.
Old Feb 18, 2005 | 01:03 PM
moogotzskillz
sry to ask. but whats the "CEL", and i do got a volt meter thingee!!!
Old Feb 18, 2005 | 04:26 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Do not post such threads in the DIY section... MOVED
Old Feb 18, 2005 | 10:07 PM
magnanpi's Avatar
magnanpi
Originally Posted by JL95AccorD
o2 sensor
um...y?
i have the same exact problem. have since i bought it over a year ago. however waht he failed to mention is that it only happens when its cold outside. plus it goes away once the temperature gauge reads closer to normal idle temperature.
so it only happens to me when ive been driving around and had the heat on...then put it in park. it goes nuts
all i do is put the ac or cold on, or turn the heat off and the car warms back to normal idle temperature... and then it idles normally
i dont have a check engine light. never have, and ive had this same problem for the past year (only affects me in winter time)
any other ideas? i really wish i could permenatly fix it. it pisses me off
Old Feb 19, 2005 | 03:34 AM
bonestock's Avatar
bonestock
check your IACV and FITV
Old Feb 19, 2005 | 03:51 PM
magnanpi's Avatar
magnanpi
ok thanks. but what exactly does that mean?
Old Feb 23, 2005 | 11:15 AM
magnanpi's Avatar
magnanpi
