idle problem????
Old Feb 23, 2005 | 01:22 PM
JimBlake's Avatar
JimBlake
IACV = idle air control valve
It's usually mounted to the back of the intake manifold, looks like a little motor. The ECU controls this to hold the idle steady. It can get sticky, so take it off & clean with throttlebody cleaner.
FITV = fast-idle thermo-valve
It's mounted under the throttle body. It's job is to raise the idle when it's cold. Clean it too, plus I guess the guts can get loose & move around which makes the idle unsteady.
Either one of these can be affected by air pockets in your coolant, so bleed out the air carefully.
Old Feb 24, 2005 | 05:56 PM
moogotzskillz's Avatar
moogotzskillz
thanxz man..... tomorrow i'm goin to check them sensors. out!! so its not the O2 sensor??
Old Feb 25, 2005 | 06:58 AM
JimBlake's Avatar
JimBlake
Originally Posted by moogotzskillz
... so its not the O2 sensor??
I guess it could be, but ICAV & FITV seem more likely. They're directly involved with idle control.
Old Feb 27, 2005 | 11:07 AM
magnanpi's Avatar
magnanpi
thank you!
