Gas Tank Capacity?
Old Jul 13, 2005 | 07:49 PM
strykernyc's Avatar
strykernyc
yes something is wrong for sure, the car should not die right away even after the gas light comes on.
Old Jul 13, 2005 | 09:33 PM
VPUPPY's Avatar
VPUPPY
Originally Posted by asnlc
i got a question. i just got my 97 integra almost 2 months ago. the other day, i was running low on gas (but the light hadn't lit up yet). however, when the light finally lit up, my car died. it was probably only the 1st or 2nd time the light when on, and i wasn't even on an incline (i was in a parking lot, might have been going over a speed bump tho). i believe at that point, i should have had 2 or 3 gallons left (13 gallon tank). is there something wrong with my tank that would cause my car to die right when the light turned on? the gauge was close to E, but hadn't hit the E yet.
thanks.
i have heard of ppl having problems with the fuel sending unit. do a search on that and it may help you out.
Old Jul 14, 2005 | 01:54 AM
sonnyhoang's Avatar
sonnyhoang
does anyy 5th gen's have that thing wtih the gas gauge of it moving up and down (ALOT) when you drive and brake?
Old Jul 14, 2005 | 08:07 AM
amadiojr's Avatar
amadiojr
i have a 5th gen, the guage will move alot if on inclines, or making a wide long turn, even if the take is close to full, but not while normally driving on level surfaces or braking, unless if you brake extremely fast. I get about 25 mpg, combo city and highway (city is alot of stop and go, and to add to that there is construction everywhere).
Old Jul 16, 2005 | 08:44 AM
asnlc's Avatar
asnlc
thanks all for the replies....will look into the "fuel sending unit"...i actually asked the mechanic about it when i went in for my 120k service....he basically talked about being on an incline and stuff....other than that...he wasn't much help...told me to bring the car back when my tank was close to empty....
boo...
don't really wanna spend more money on my car...guess i can live if the car dies when the tanks just getting low....grrr...plus my A/C doens't work on control #'s 1 and 2...3 and 4 work....wonder what's wrong with that....
Old Jul 16, 2005 | 07:24 PM
motoguy128's Avatar
motoguy128
You don't need a fuel gauge. You can use the tripometer/odometer. Most motorcycles don't have fuel guages and hte tanks are terrible small, so you learn to ride unti lyou get to 120-150 miles then refuel.
OS if you know what the typical mileage is for that tiem of year and road conditions, then just only use 10-12 gallons of ht ecqapacity and caculate your range based on that. SO if you get 30mpg on the freeway, you should refill between 300-360 miles without worry of runing out of gas. In city driing when getting 20mpg, you can stop safely after 200-240. Etiher way, your looking at at least 6 hours of fuel.
Old Jul 17, 2005 | 04:46 PM
guessboi2003's Avatar
guessboi2003
95 Accord EX V6
i get shitty gas mileage all the time...and my gas guage flutuates DRASTICALLY and who knows how much gas i really have at any point in time...i have a 95 EX V6 sedan...any advice???
Old Jul 17, 2005 | 05:37 PM
motoguy128's Avatar
motoguy128
You should still be a ble ot use a conservative number like 18mpg to determine when you should refuel. So after 200 miles, you'll want to look for some gas. On the freeway, you should still be a able to go 250 miles.
For improving your mileage. The usal things such as air filter, spark plugs and clogged injectors can cause this. Be sure to use regular 87 octane.
Most of all how you drive makes a big difference. Look down the road, don't race up to lights, and use the gas pedal very smoothly. In most cities the traffic lights are timed so no matter how fast you go, you'll get there in the same amount of time... just drive the speed limit. Make only very small motions when holding a steady speed, let you car slow down a little going up hills and speed up on downhills. Keep you speed when possible over 35 mph to get it into 4th gear, and stay under 70mph. Follow all of these closely and you can imporve yoru mileage by at least 10%.
