Oil problem with 98 accord
Old Dec 10, 2004 | 07:59 AM
gweedo14's Avatar
gweedo14
Default Oil problem with 98 accord
I have a 1998 accord that usually around the time for an oil change, the engine loses oil. This has already happened like 5 times since I got it and everytime I take it to the shop they say that they can't seem to find out what is wrong with it. Does anyone have any clue what is going on with this?
Old Dec 10, 2004 | 08:18 AM
skabone69's Avatar
skabone69
do you mean why are you burning oil in between oil changes? its a typical problem on the 6th gen accord. Check your spark plugs. I've also been using engine restore in between oil changes and that seems to have help the situation.
Old Dec 10, 2004 | 11:00 AM
gweedo14's Avatar
gweedo14
Yes. Maybe I'll try that. Thanks alot
Old Dec 10, 2004 | 11:21 AM
carrnut21's Avatar
carrnut21
Banned
How much are you losing between changes, and how often do you chnge it?
Old Dec 11, 2004 | 02:09 AM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
wat oil u using?? if it's synthetic oil, it tends to burn a lot faster than mineral oil...
Old Dec 11, 2004 | 07:34 AM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
I loose a .5-1.0 quarts between 5000miles that's normal for folks romping on the VTEC. Don't worry about it.
As long as you don't go below the second dot on the dipstick you are fine.
Old Dec 11, 2004 | 07:54 PM
h22accord's Avatar
h22accord
155mph and still climbing
Im with you on that one. If i have for the most part babied it then i will a lose a normal about of oil about 1/4 to 1/2 quart but if i stay on it all the time when it comes time to change i am usualy about a quart or a quart and a quarter low.
Old Dec 14, 2004 | 11:26 AM
acguy's Avatar
acguy
Don't wait until 5K to check oil??
Old Dec 14, 2004 | 01:02 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
My J30A1 used to burn about a quart every 3k miles...it was getting pretty bad. Then I switched to castrol full synthetic and it hasn't burned a single drop since :dunno:
Cars lose oil as they age...seals break down, your engine becomes less efficient. It's a fact of life. Cleaning out your throttle body, changing your spark plugs, and pouring some seafoam into your crankcase and PVC vacuum hose will clean out the carbon deposits in your engine. That might help it.
Old Dec 15, 2004 | 09:56 AM
Esco5710's Avatar
Esco5710
I just posted the same issue with my 99 accord.. I guess the 6th generation do have this problem.. My seems to burn it within 1500 miles.. Im a try that restore like this guy had mentioned and see if it works... He said it worked for his...
