spark plug wires...
Old Dec 9, 2004 | 05:56 PM
mikev88's Avatar
mikev88
Default spark plug wires...
Just wondering if it's normal that when i remove the wires(engine is running) from the plug while i'm pulling them out of the hole the fire is jumping I can see sparks going from the tip of the wire to t he metal of the valve cover(at night). I thought that they were supposed to be insulated and no fire should jump from them but then again maybe it's because i unplugged them and the volatage is high enough for this to happen. If anyone could tell me , i'm suspecting i have bad wires.
Thankx
1993 Accord
Old Dec 10, 2004 | 05:21 AM
mikev88's Avatar
mikev88
c'mon anyone?
Old Dec 10, 2004 | 06:27 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
I guess it could be bad wires. I know I've been shocked before while holding a wire that was not damaged. It has something to do with grounds, or lack thereof...
I change my wires regularly so I never worry about them going bad.
Old Dec 14, 2004 | 11:34 AM
acguy's Avatar
acguy
Default Ignition of accords
The ignition system in your honda is very strong, and I actually saw a guy unplug all four wires, but let them lay in the tubes, and the car started and ran......
One thing for sure on a Honda is a good ignition spark.
Old Dec 14, 2004 | 11:12 PM
strykernyc's Avatar
strykernyc
is it even normal to unplug those wires while the engine is running? i think it is logical to see fire spark if you try to unplug the wires when the engine is running.
Old Dec 15, 2004 | 09:03 AM
mn__30's Avatar
mn__30
That is normal.
