Accord Squeaking Problem
Old Dec 8, 2004 | 01:13 PM
n33lu's Avatar
n33lu
Default Accord Squeaking Problem
Hi Guys:
Whenever I start my car, I hear a loud squeak from uder the hood. It is hard to isolate where the squeak is coming from. The squeak goes away after the car starts. It is louder on colder days. I took it to the local mechanic and he said that it is probably the starter.
I am wondering if anyone has had this problem before or if anyone knows the fix to this.
thanks,
-n33lu
99 4-cyl Accord
Old Dec 8, 2004 | 02:43 PM
mn__30's Avatar
mn__30
It is a loose belt.
Old Dec 8, 2004 | 05:08 PM
n33lu's Avatar
n33lu
if it were a lose belt wouldnt it squeak all the time instead of just when I crank it?
Old Dec 8, 2004 | 07:20 PM
wedley2's Avatar
wedley2
bboy Wesley West
well, after the engine warms up the temp under the hood increases. doesnt rubber expand under heat?
Old Dec 8, 2004 | 08:22 PM
hype8912's Avatar
hype8912
Dr. Klaw
the rubber on the belt gets stickier as it heats up which allows it to grab and not squeak anymore.
You'll have to replace the belt or it will continue to squeak till it breaks.
Old Dec 9, 2004 | 05:49 AM
JimBlake's Avatar
JimBlake
Try some belt dressing. It's not gonna fix it permanently, but you can use it to convince yourself that it's the belt. Or not the belt...
Old Dec 9, 2004 | 07:55 PM
n33lu's Avatar
n33lu
What is belt dressing?
Old Dec 10, 2004 | 05:38 AM
anubis989's Avatar
anubis989
Somebody Teach ME
Question, anyone know what belt it is, I just started having the same problem after getting my tune up.
Old Dec 10, 2004 | 06:31 AM
2kAccord's Avatar
2kAccord
#010597
In my old accord the P/S belt used to do that. When you did the tune up did they change any belts? or did they leak fluid on them?
Old Dec 12, 2004 | 09:06 PM
n33lu's Avatar
n33lu
They changed the timing belt and all the drive belts. Whats a P/S belt?
