I think there might be something wrong with my steering.
Old Nov 10, 2004 | 08:25 PM
nhatters's Avatar
nhatters
I don't always do that, just lately because it felt weird.
Old Nov 10, 2004 | 08:32 PM
axemansean's Avatar
axemansean
Check your tire balance and alignment. Tire pressures are preferential for most people. For instance I run mine at 36 psi, much higher than most people do for plain old street use.
Old Nov 10, 2004 | 08:52 PM
wedley2's Avatar
wedley2
bboy Wesley West
damn, and i thought 34 was high...
Old Nov 12, 2004 | 10:16 PM
nhatters's Avatar
nhatters
Nope! It was the air.
I checked all of the tires today because the weather had suddenly gotten very cold and this is what the tires were out of 30 PSI: 27, 25.5, 24, 27.
I filled all of them up to 30 again and now the steering wheel doesn't shake, and when I come out of a turn, completely smooth.
Old Nov 13, 2004 | 03:10 PM
TaekOne's Avatar
TaekOne
pronounced tech
its my understanding that when you check your tire pressures, it should definitely be beFoRe driving, and if you have, less than 10 miles (or was it minutes...?). temperature of your tires makes a big difference to the pressure, so if youve been driving around a lot and checking the pressures immeditately following, dont expect those readings to be consistent. those things heat up pretty quick, even in cold weather.
not tryin to insult anyone's intelligence, just tryin to be helpful >:]
holla
Old Nov 13, 2004 | 07:27 PM
nhatters's Avatar
nhatters
holla
Yeah, I knew that. And I thought it was 1 mile?
Old Nov 14, 2004 | 09:06 AM
wesside's Avatar
wesside
2005 Evo Rs @24psi
my tires are 205/45/17 max psi is 44 I run them @ 38lbs
Old Nov 30, 2004 | 02:41 PM
nhatters's Avatar
nhatters
I just thought of another question:
If the manual says 30 psi, but the tires say 40, which do you follow?
Old Nov 30, 2004 | 04:38 PM
jschmid's Avatar
jschmid
If you look at it again, it probably says that 40psi is the MAX psi, not the recommended psi. 30-34 should be good for the stock size tires.
Old Nov 30, 2004 | 04:48 PM
nhatters's Avatar
nhatters
Ah, I see. Thanks.
What do you have yours at? Would you want more in for winter or less? Or would it depend on what kind of roads you drive on too?
