Clutch or Oil?
Old Nov 4, 2004 | 08:24 PM
shondaaccordex's Avatar
shondaaccordex
Default Clutch or Oil?
I have recently noticed a hot smell while driving my 92 accord. It does not happen until the car has been running for a while. My gauges are fine and so is the oil level. Two things I think it might be. I have a small oil leak on the intake manifold side of the block. A location has not yet been determined. I think that the smell might be coming from the oil leaking onto hot parts of the car (ehaust pipe) and that is causing the smell? The other theory I have is that might clutch is going out. In first gear, obviously I have a manual, the car shimmies when starting out. I wondered if the smell was coming from a burning clutch?
Old Nov 13, 2004 | 05:52 AM
BetterBob's Avatar
BetterBob
Nobama
most likely oil, you have to wear on the clutch HARD to be able to smell it... the shake's doesent mean the tranny is going out most of the time... just uhh driver error
hope i helped
Better_Bob
Old Nov 13, 2004 | 12:45 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
If your enegine is fine,.. it's the oil leaking on the hot parts of the car.
Old Nov 13, 2004 | 11:55 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Burning clutch fluid and burning oil are two completely different distinct smells. Some clutches smell when they are going and some don't, so if it smells like clutch fluid, it may be something to look at. Oil dripping on the exhaust could mean a bad oil pan gasket and should be replaced.
Old Nov 14, 2004 | 10:45 AM
Cosmo M3's Avatar
Cosmo M3
Lurker
I hope you guys are aware that if oil leaked onto the exhaust pipe, it would cause a fire, just like like the new CRVs because the technicians didn't tighten the oil pan screw after an oil change.
Go get it checked out at a shop.
