Rear camber installation
Old Oct 14, 2004 | 09:50 AM
flyromeo3's Avatar
flyromeo3
Default Rear camber installation
02 accord sedan exL
ok since I have been having this problem with my rear camber (even though my car is stock height, stock springs etc....) my conclusion is just to get a camber kit and correct it that way.
I bought tires (Falken ZIEX 512's in April and already have to replace my rear ones becuase of uneven tire wear on the inner side of the tires....
How hard is it to install the camber kit? Can I do it myself and then take it to get adjusted. If its an easy install id rather do it myself so i wont get charged an arm and a leg for the price. I removed the tie bar i had because i felt that caused the problem. I removed it to late cause I figure the tires already wore out and got that uneven shape.
Which camber kits are good to get?
eBay as some and not sure which brand is preferable.
Old Oct 14, 2004 | 01:48 PM
jschmid's Avatar
jschmid
Here's a DIY I did: https://www.honda-acura.net/forums/s...ght=camber+kit
Old Oct 14, 2004 | 02:38 PM
wedley2's Avatar
wedley2
bboy Wesley West
make sure u get the right camber kits and not camber links.
Old Oct 15, 2004 | 04:51 AM
flyromeo3's Avatar
flyromeo3
I was told that they could place me car up on a lift.
Unbolt the strut from the bottom and let the rear wheels kinda hang there.
Then lower the car, put weight on the back and then tighten the bolts.
I was told thats how they align the rear wheels.
Jesus!!!!!! why am I having this problem on a new car!...ohh well.
Old Oct 15, 2004 | 05:22 PM
jschmid's Avatar
jschmid
There is no stock adjustment for camber. Why not just get a camber kit if you are so concerned about it?
