brake bleeding
Old Oct 3, 2004 | 09:11 AM
buster133's Avatar
buster133
Default brake bleeding
The bleeding sequence is Front Left, Front Right, Rear Right and Rear Left. I have done this on my 02 EX V6 and it worked out perfectly.
Old Oct 3, 2004 | 02:06 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Don't think so.
The rule of thumb has been you start with wheel furthest from the master cylinder,.. and then you work your way around.
They can be bled like you said,.. but the experts say not to do it that way.
Old Oct 3, 2004 | 05:19 PM
buster133's Avatar
buster133
Default brakes
Well, I guess the experts were out sick on the day this page was printed into the 98-02 Helms Accord factory service manual as it shows the sequence exactly as I had mentioned above.
File Type: jpg
Old Oct 3, 2004 | 07:43 PM
wedley2's Avatar
wedley2
bboy Wesley West
they are wrong.
Old Oct 4, 2004 | 01:21 AM
buster133's Avatar
buster133
This sequence is also printed in the Chilton 96-00 Accord/Prelude service manual, and the procedure listed above is only mentioned for 98-00 Accords and Preludes, the 96-97's show the way you mentioned.
Old Oct 4, 2004 | 04:30 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
I'm not sure why that manual says to do it that way.
For eons it's been the way I said.
HMMM...
Old Oct 4, 2004 | 05:00 AM
klnyc's Avatar
klnyc
Bah, I done all different ways and result is the same. People do the furthest one 1st, but I would go what the manaul says.
Old Oct 4, 2004 | 07:29 AM
JimBlake's Avatar
JimBlake
The old-old way is work your way from farthest to closest. Then in the '60s with dual/diagonal brakes, you start with the farthest then go diagonally opposite. So that would be RR-LF-LR-RF.
Then with ABS the order is based on which circuit is more likely to push bubbes into which other circuit. That depends on the plumbing details around the ABS modulator, not the distance to each wheel.
Old Oct 4, 2004 | 09:15 AM
flyromeo3's Avatar
flyromeo3
for such a new car why do you need to bleed the brakes already?
Old Oct 4, 2004 | 01:13 PM
klnyc's Avatar
klnyc
Maybe he changed to SS brake line?
