1994 Accord ABS question
Old Sep 19, 2004 | 04:24 PM
tawd77's Avatar
tawd77
Default 1994 Accord ABS question
Hi, I have a 94 accord with abs problems. I have read through others posts about this issue but still dont know whats wrong... What happens is, when I start the car the abs light goes out, and you can hear the abs unit under the hood making a buzzing noise for about 1 minute. Then the bussing stops, you can hear a relay click under the dash, and the ABS light comes on and stays on. I jumped the Diag. wires and it was throwing a code, but im not sure how to read it. do you start counting blinks as soon as the key is turned on? As soon as i turn the key, the light is on solid for a sec (like a long blink) and then does 2 short blinks, and then a longer pause, and then another short blink. The car has been wrecked and the Right rear wheel is shoved in the fender quite a ways. So im wondering if that screwed up the wheel sensor for that wheel? Any help would be great!! Thanks
(oh yeah, the break pedal is kinda funny... If you just sit in the car and hold down on the brakes, the pedal will slowly go down to the floor. BUT, its not leaking any fluid. I thought maybe there was some air in the lines, but that will usually give a spongy pedal, not a leaking feeling pedal. Any ideas if this has to do with the abs, or whats wrong? Thanks)
Old Sep 19, 2004 | 11:02 PM
tawd77's Avatar
tawd77
Old Sep 20, 2004 | 08:38 AM
JimBlake's Avatar
JimBlake
Check out this thread.
https://www.honda-acura.net/forums/s...d.php?t=150737
About halfway down I posted some instructions. That's for an integra, I can only guess that '94 Accord is similar. So maybe it's 2-1? That's a parking brake problem?? But what you describe sounds like pump motor over-run, so it should be 1-. I guess you'd have to pay attention to how long the pauses actually are.
Maybe Accords have a different list of codes?? I got that straight out of the Helm manual for '95 Integra.
