swap, plz help
nah man, i want somthing that will a stock sound, i mean i can always get stock looking tips, if not slightly larger, the throaty sound be coming straight from the qtec, which opens up electronically, cutting out the catalytic converter on demand, but i need the larger pipe to feed it, and thats basically what i'm loking for
if you're going for turbo, then it's not even worth it trying to keep to keep it close to stock because all that would do is building up the back pressure. Save the money and get a good muffler and a 2.5" mendrel bend piping from the catalytic converter end to the muffler. Later on, when you're going for turbo, all you need is a new straight pipe to replace the catalytic converter in addition to the down pipes and suches from the turbo package.
