big brake kit?
Old Jul 20, 2004 | 05:33 AM
axemansean's Avatar
axemansean
Thanks mate. Solves my big brake problem.
Originally Posted by Ben95ex
yeah, the 4th gen wagon, 5th gen wagon, and 5th gen V6 all used the same brake setup with 11.1" x 25mm rotors and nissin calipers. in order to use the larger rotors you would also need a complimenting caliper made for that diameter and width disc. so any of the calipers from the afformentioned cars, or those from a VTEC 4th gen prelude should also work.
legend and NSX calipers can be used since they were designed using the same bracket [28T] but the pads should be shimmed up if you're using anything less than a 25mm wide rotor.
Old Jul 20, 2004 | 08:13 AM
Intrepid241's Avatar
Intrepid241
Originally Posted by Surfacing171
:squint: Tenzo products are sorta ehh....
Why because they're cheaper than most?
Old Jul 20, 2004 | 08:35 AM
Surfacing171's Avatar
Surfacing171
cb7 fanatic
No, because they are know for the their poor quality. How many cars do you see sporting Tenzo brakes compared to Brembo, Powerslot and AEM to name a few? Tenzo just makes shitty prouducts.
Old Jul 20, 2004 | 09:11 AM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
werd.... but some of their rims look hot tho!!
well, thanks for all the help guys.... been very informative... might look into getting it done by the end of the yr...
Old Jul 22, 2004 | 11:52 AM
gadamiii's Avatar
gadamiii
What sort of improvements could I expect from upgrading to Type-S Brakes versus my 99 v-6 sedan brakes? What is the rotor diameter difference? Does the Type-S have dual piston calipers?
Old Jul 22, 2004 | 04:58 PM
Ben95ex's Avatar
Ben95ex
none, the brake dimensions are identical as are the calipers and the pads. [i'm almost positive]
however, since you already have bigger rotors and a 5 on 114.3" bolt pattern you could very easily use the legend Coupe calipers and rotors by just swapping them out for your stock setup.
the only honda calipers i'm aware of that have dual pistons are: NSX, 2004+ MDX, and 93-95 Legend Coupes and Legend GS sedans. all should use the 28T bracket [or something compatible] which will work with the legend rotors.
