92 Accord Trunk Vent-water leak
Old Jun 30, 2004 | 03:27 PM
Ike's Avatar
Ike
Default 92 Accord Trunk Vent-water leak
I have a question for everybody:
What's the purpose of the trunk vent flap on the driver's side quarter panel in my 92 Accord EX Coupe? I am getting a water leak around the gasket (after rain) without even driving the car. From the looks of the vent's flap seal design I don't see how it kept water out with a good perimiter gasket......kinda wondering why Honda put this vent in the trunk...
What will happen if I remove the vent assembly and replace with a piece of 1/8" aluminum ?......doors or trunk lid hard to shut?
Has anybody ever run into this before?
Any ideas, experiences, or suggestions will be greatly appreciated
Ike
Old Jul 1, 2004 | 02:47 AM
BONE's Avatar
BONE
I had a similar experience with my 88 Accord its not a trunk vent seal its the sun roof drain line its probably clogged up what I did was cut the tip off of it and blew out the line and hadn't had any problems since hope this helps.
Old Jul 1, 2004 | 05:37 AM
JimBlake's Avatar
JimBlake
The purpose of that vent is to let air out from the cabin when you have your ventilation blower going. There's a gasket (or caulking?) around where it's mounted, it doesn't have to be leaking in thru that flap. But check sunroof drain tubes & taillight gaskets too, if you're not sure where the leak is...
