Spring Installation/spring compressor
Old Jun 20, 2004 | 09:38 PM
lowrideacc's Avatar
lowrideacc
Default Spring Installation/spring compressor
I need help installing my springs. I am replacing my cheap coilovers with H&R springs. My question is, do I need a spring compressor to install my new springs? I did not need a compressor to unistall my coilover/kyb agx assembly, but now that I am putting lowering springs on, I could not get the assembly to fit back in. So if I use a spring compressor to compress the spring to make it the same size as the coilover, i would easily be able to fit it in and bolt it in. Is that correct...or is there an easier way to fit the bigger springs in without going out and getting a compressor.....I have never needed to use a spring compressor before, but now I am stuck with these springs! thanks
Old Jun 20, 2004 | 11:47 PM
syclone's Avatar
syclone
i doubt you do.. make sure you have a friend helping you.. the spring should touch the top mount and you'll probably have to push it down a little while your friend threads the nut in a little.. but i haven't had a need for spring compressor yet to install aftermarket springs..
Old Jun 21, 2004 | 07:19 AM
SWOOSHER21's Avatar
SWOOSHER21
Fight Rice
autozone.......$40 deposit that you get back when you return it.
Old Jun 21, 2004 | 08:26 AM
lowrideacc's Avatar
lowrideacc
Do I just bolt down the shock/spring down while the spring is compressed, then when I have it installed, I uncompress it? Is that how it works?
Old Jun 21, 2004 | 11:32 AM
syclone's Avatar
syclone
if you're working without a spring compressor, you can just thread the nut then uncompress it to focus your attention to tightening the nut. if you're using a spring compressor, go ahead and tighten the nut all the way before you uncompress it.
Old Jun 21, 2004 | 04:31 PM
wedley2's Avatar
wedley2
bboy Wesley West
they are only like 20 bucks off ebay, bought mine and worked well.
u probably do not need oen for installing like syclone said but for removing if you dont have one, it will shoot off.
Old Jun 21, 2004 | 04:37 PM
syclone's Avatar
syclone
Originally Posted by wedley2
...for removing if you dont have one, it will shoot off.
that's only if he had the oem springs on there.. but he mentioned that he has the coilover sleeves on there currently which is probably not even touching the top mount when it's fully extended...
Old Jun 21, 2004 | 04:47 PM
wedley2's Avatar
wedley2
bboy Wesley West
oh, my bad.
Old Jun 22, 2004 | 06:23 PM
lowrideacc's Avatar
lowrideacc
Well I rented the spring compressor from autozone and I used it to install the rear springs....It was fairly easy, but I am having a problem with the front now. The spring compressor does not fit in between the coils, so I cannot compress it. I'm almost positive that I need to compress the springs because when I re-installed the coilover, it was so easy...it fit right in, but when I try to install the spring, I couldnt even come close to bolting it in. I think I am just gonna take it to a shop and have them do it along with an alignment.
Old Jun 23, 2004 | 01:32 AM
syclone's Avatar
syclone
well, if it's a coilover.. just lower the perch all the way down...
