AC compressor help
Old Jun 8, 2004 | 07:09 AM
mohamed_ibrah's Avatar
mohamed_ibrah
Tech in Training
Originally Posted by hondatech
You tryed adjusting it i take it? I disconnect the valve cable under the hood at the firewall, then I turn my knob to cold on the dash, then I set the heater valve to close. Then I hook back up the cable and lock the clip in place. Mine stays closed fine. You might have a bad valve or something, I see that from time to time. If you want to know for sure use hose pinch plier's and pinch off the heater hose after the valve. Then see if you get a cooler temp. reading. I do this on every car when checking the a/c performance.
It's exactly what I did, slip off the clip, heat control to cool, turn valve all the way to closed postion, slip back on and clip holder into place. It just doesn't seem that it can push the lever all the way shut. It works fine now for the time being, besides I don't have a personal Raytech gun to get a good shot read. When class starts back up again (August), I use the school's gun and if I get a significantly higher effluent from the valve, I figure next time I need to drain my coolant and refill, I'll change out the valve then.
Old Jun 8, 2004 | 07:11 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
I might go back to school in augest, what are you taking? I'm thinking about mostly the smog stuff, maybe the body shop class.
Old Jun 8, 2004 | 07:45 AM
mohamed_ibrah
Tech in Training
Small Engine Repair, then in Spring 2005, either auto or manual tranny.
SMOG is a good course to take and will make you even more valuable if you pass the ASE (as you already know).
Old Jun 8, 2004 | 07:50 AM
hondatech's Avatar
hondatech
yeah, i have all my ase's now and my basic smog lic. , i just need the enhanced lic. to smog in sacramento. then I can get a second job doing test only smogs on my days off.
