accord overheating help needed
Old May 16, 2004 | 02:09 PM
customx's Avatar
customx
Default accord overheating help needed
i have an '86 honda accord and need some help to figure out whats wrong with it. i noticed about a month ago the car was overheating so i put in some antifreeze and water and then the temp gauge was fine. last nite it started heating up again so i put more antifreeze and water in today. after driving about 1/2 hour the car started to heat up again to the point where when i was at a complete stop steam was coming out from under the hood. last year i replaced the alternator which took care of my runnaway engine, i've had the master cylinder, clutch, brake lines, water pump replaced and the radiator flushed out. the radiator was flushed out a really long time ago (4 years) so i think this may have something to do with it. if any of you are car pros i'd appreciate any help. the cars a POS and im about to just get rid of it if repairs are too much. thanks
Old May 16, 2004 | 05:11 PM
accordvtec77's Avatar
accordvtec77
Could be almost anything. Could be the radiator, a heater hose, radiator hose, stuck thermostat, or blown head gasket. See if you can see anything leaking while the engine is running...
Old May 16, 2004 | 06:53 PM
SonY:)AccOrd's Avatar
SonY:)AccOrd
GOSU
how old is your radiator? mine was getting hot a lot but once I replaced my radiator and all the tubes and hoses it worked fine and stayed at a good temp
Old May 17, 2004 | 06:26 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
There's a fan switch that needs to be replaced every once in a while.
Make sure you bleed the air out of the system after changing.
If you do a seach,.. you should find a ton of threads on this topic.
Justasking
Accord
10
Feb 18, 2004 06:17 PM
sphinx054
Accord
6
Jan 18, 2004 08:52 AM
hondav6
Jul 17, 2003 08:52 AM
SumAccordGuy94
Jul 1, 2003 07:28 PM
