Clutch issues
Old May 5, 2004 | 07:22 PM
6genx's Avatar
6genx
Swami
Default Clutch issues
It's been 15k miles since I installed my flywheel and clutch set...clutch is oem. For about the last 7k miles my clutch doesn't engauge until there's about 1" left in the pedal release. Way worse than the stock flywheel was doing with a burned clutch and pressure plate. When I borke it in, the first 1000 miles I was taking it easy, no riding clutch or hard shifts, and taking the long way to work to avoid traffic. I was wondering if I should have steped up to a clutch set with more clamping force than stock, (intake and header the only engine mods). What do you guys think?
BTW.
I am about to finally change my cabin filters...I'll take pic's of what they look like after 120k miles of Georgia pollen.
Old May 5, 2004 | 07:28 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
So I assume you installed a new OE clutch with the new flywheel?
You have to lauch a bit higher in the RPM band at starts, right? I would assume this helped kill the clutch early, may just need a stage 1.
Let me know what you install next, I was planning on using a fidenza flywheel and exedy stage 1 when the time comes.
Old May 6, 2004 | 04:04 AM
skabone69's Avatar
skabone69
I just upgraded to a stage 1 this past summer and after upgrading from OEM I'd recommend a street clutch upgrade. Its just a shame that you wasted your money on a new soft OEM clutch. you get a ton more clamping power with just a stage 1 clutch. I've got the ACT street disc and love it. Exedy is also a great clutch.
sonicrex
Jan 21, 2004 07:05 PM
draggin
92+ Civic/EL & Del Sol
7
Dec 1, 2003 08:08 AM
AwwsChwA
Engine Swaps, Tech & Tuning
3
Apr 15, 2003 11:17 AM
98CoupeV6
Do It Yourself
Jan 17, 2003 05:11 PM
[hC]
9
Aug 21, 2002 12:03 PM
