More Brake Questions...
Old Apr 15, 2004 | 06:35 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
Default More Brake Questions...
Everyone here is aware of the warped front rotors deal. I put new rotos and pads on the front of my car in november I believe, Autozone rotors and Honda pads. The pads have yet to show ANY signs of wear... but the rotors are warped to all hell. I seriously cant hold the steering wheel when I brake comming from highway speeds.
The first thing that comes to mind, is better rotors... weather it be just a better brand, or even some drilled rotors. What has been your experiences with rotors? What seems to work for you? I do tend to brake kind of hard, so I definatly need something that will hold up. I would definatly like to do cross-drilled rotors, but not sure what ones to go with.
I also want to do a larger brake upgrade. Not a readily available kit, but something put together that will fit the car and work properly. So Accord V6/wagon/97 3.0 CL brakes come to mind. Which is what i'll probably go with, just for some increaced surface area. My CL never had a problem with warped rotors, and its a heavier car... it seems like only accords I have this problem with. My 90 EX did the same thing, ate through rotors... as well as my moms old 91 SE.
All your advice is greatly appretiated... I want to know actual experiences... I dont want to buy something just because "its a good brand".
One more thing..... is there such thing as rotors that dont rust? Or at least as much? I'll be putting my 17s back on this summer and would like the brakes to look a little better.
Old Apr 15, 2004 | 08:05 PM
Bl@ck's Avatar
Bl@ck
Sinner
who put the rotors on? if they tightened the bolts down too tight that could cause them to warp over the span of a few months.. make sure whoever puts the new ones on torques them to honda specs
Old Apr 15, 2004 | 08:42 PM
SumAccordGuy94
Older Honda Fanatic
I put them on. You're talkin about the bolts that hold the rotor to the hub, right?
Old Apr 15, 2004 | 08:53 PM
Bl@ck's Avatar
Bl@ck
Sinner
yep... also, i think if your lugs aren't torqued to specs it may also cause rotors to warp.. i could be wrong though
Old Apr 15, 2004 | 09:24 PM
SumAccordGuy94
Older Honda Fanatic
probably on a rotor-over-hub car... but I know if the lugs are not torqued right, the car will shake as if the tires are not balanced properly.
The rotors I have are still under warranty I believe, so I'll just get 'em replaced for now... then when I can afford the upgrades, I'll do it. Plus I dont wanna waste $50 pads that are not worn at all.
Old Apr 15, 2004 | 10:48 PM
usc's Avatar
usc
Honda is synonymous with rotor warping. This is true with Accords, CL's and TL's at least.
The only solution I've found is with:
...but that itself created another set of headaches.
Old Apr 16, 2004 | 09:01 AM
accordhybrid's Avatar
accordhybrid
you can covert your Hub over Rotor design to the Rotor over Hub design and depending if you want the 10.2 inch rotors or 11.0 inch rotors will tell you what other parts you need.
accordhybrid
Old Apr 16, 2004 | 09:03 AM
axemansean's Avatar
axemansean
Yep warping is common... try getting some Brembos and having a shop put it on.
ambition
4
Mar 27, 2003 08:14 PM
VtecApprentice
Engine Swaps, Tech & Tuning
5
Feb 10, 2003 07:12 AM
