Cam Seal needs replacement
Old Apr 8, 2004 | 03:58 AM
sa863c's Avatar
sa863c
Default Cam Seal needs replacement
Has anyone done the cam seal on a f22?
Do you need the special installer tool?
Do you need to take out the rocker girdle / cam retainers?
Do you need something to hold the cam like the honda service manual shows?
My thoughts on the process were this:
1. take of valve cover
2. take of top timing cover
3. mark cam and timing belt w/ grease pencil
4. slide off belt / remove cam gear bolt
5. remove old seal
6. put in new seal
7 re-install in reverse order, making sure that the marks on the belt/gear line up.
Honda wants $220 to do this...the damn part was $5.
Old Apr 8, 2004 | 05:04 AM
flyromeo3's Avatar
flyromeo3
5. remove old seal
6. put in new seal
Sounds easy to do.
If you do go to Honda your paying that 220 in case they **** it up. If so, then they fix it.
If you do it and something messes up you will pay more to fix your mistakes.
there go your two options.... = )
Old Apr 8, 2004 | 06:14 PM
MrChad's Avatar
MrChad
THE RED 6th GEN Coupe
The cam needs a special tool for the cam seal to be installed.
According to the helm manual you can order the tool from Honda with you new seals. The manual lists the part no of the tool.
nonbox
14
Feb 29, 2004 10:54 PM
nonbox
Engine Swaps, Tech & Tuning
Feb 27, 2004 01:15 PM
TotoTeg
3
Dec 3, 2003 02:39 PM
FurBall
Accord
2
Dec 7, 2002 07:04 PM
VtecApprentice
20
Nov 30, 2002 08:02 PM
