Difference between Koni Reds & Koni Yellows?
Originally Posted by Samson
why do u have to lift the car to adjust the yellows? seems dumb since that takes more than a few secs.
The dampening can be done by just twisting the dial on top of the shock. No lifting necessary. Thats real easy for the fronts, but access to the rears is a real pain.
Originally Posted by Mr Hyde
You have to lift the car to adjust the perch, which can adjust the height. Thats no different than any other coilover system out there. Unless you have an air suspension, you need to jack up the car to adjust height.
actually if you can compress the spring while it is still on the car, you can do it without removing the shock. Was able to do it on mine.
integra-boy
10
Aug 30, 2002 10:20 AM
