strange engine sound at 1500-2500 rpms
Old Jan 22, 2004 | 05:36 PM
MichaelT1960's Avatar
MichaelT1960
Default 94 Accord EX strange engine sound at 1500-2500 rpms
A month or two ago I changed the coolant in my 1994 Accord EX -Sedan.
While reving up the engine to heat up the coolant faster I noticed a strange engine
tapping or knocking sound around 1500-2500 RPMs. If I goose the throttle it
seems to be even more noticeable...like a dieseling sound.
The dealer mechanic said it sounded like piston slap. A second dealer while in NC said he thought it sounded like the balancer shaft belt wasn't set right.
When I returned home to NY I had my dealer look at it and he a bunch of mechanics listened to it They took off the valve cover and front (top) engine cover and said everthing looked ok.
But how could they have checked the balancer shaft belt without removing the lower engine cover(crankshaft pulley)? Is it possible? My timing belt / water pump was changed 2 years ago by them around 92000 miles. I now have 112K miles and although the engine runs fine there is still this tapping sound when in neutral (at 2K rpms or so).
The dealer diagnose now is main or rod bearing problems. Most likely Main engine bearing.
How could I have this problem on a car
that since new I have only used Mobil 1
5W30 Oil??? Changed between 5 - 6000 miles???
Would going to a heavier weight oil help (5W40 or 10W40)?
They say that the next step would be to drop the oil pan and take a look.
The dealer also said a mis-aligned balancer shaft belt would cause engine vibration. Even off 1 notch??
Any expert Honda mechanics out there??
Your comments would be appreciated!
Thanks,
Michael
Old Jan 14, 2009 | 09:51 AM
wellsboy365's Avatar
wellsboy365
mine did the same thing. i cant remember what its called but its where your gases that will not burn go. 3 out of 4 were clogged on mine
do this and im pretty sure you will be running right
Old Jan 14, 2009 | 07:48 PM
Driver's Avatar
Driver
slow lane cruiser
The EGR valve going bad won't cause tapping. (Exhaust gas recirculation valve) Balancer Shaft? Harmonic Balancer perhaps, again no.
Sound like valve lash. Get the valve clearances checked out, IMO that's what it sounds like the problem is.
Good luck with it man, but I must say for that many miles on that year of honda a little valve tap is not uncommon.
Old Jan 15, 2009 | 02:04 PM
is there any scent of gas?
that diesel noise can be caused by a bad engine coil.
Old Jan 15, 2009 | 07:36 PM
cruzalekz's Avatar
cruzalekz
just something to think about.
this all hapenned after u did the coolant change right? im just guessing you probably did not do the coolant flush correctly, say maybe, just maybe you developed air pockets in your cooling system and maybe when it (air pockets) reaches the waterpump, you hear the engine noise that you are hearing.
