fuel injector cleaner
Old Oct 20, 2003 | 08:00 PM
Jack the Ripper's Avatar
Jack the Ripper
Banned
From: Whitechapel (Not really, goes with the theam)
Ok, here is what I tell everyone about this subject.
FI Cleaner is like 90% alcohol(sp) so why buy tit for $2-3 when you can use rubbing alchol from wal-mart for $.98 a bottle.
I use rubbing alchol once every 6 months and have no problems. I pour in asmall bottle on half a tank. then fill it up. then runt he tank down to below 1/4, then fill it up. and go from there.
It will clean the FI better then any cleaner you can buy and it will burn just slightly hotter for a few days and clean the sparkplugs and the rest of the fuel system.
Anyways. thats my $.02 I have been doing it for 5 years now and have had no problems.
BTW if you do this a bottle of rubbing alchol will have a % number on it. get the highest % you can find. I have found no higher then 97%
Old Oct 20, 2003 | 10:25 PM
polakatl's Avatar
polakatl
Why haven't the FI producers figured this out? I can't believe that rubbing alcohol can be better than a purpose produced chemical. I'm not saying it won't work but it seems too simple.
Old Oct 20, 2003 | 11:04 PM
92lx
Guest
Posts: n/a
hrmm... I'm going to have to do some chemistry research on that one.
- Nathan
Old Oct 20, 2003 | 11:30 PM
showgunz's Avatar
showgunz
Not to bust you on this idea but not all fuel components of a gasoline engine car are compatible with alcohol. I'm concerned because my college's engineering project involved turning a gas engine into an E85-compatible one. Granted, you're not using that rubbing alcohol very often but I wonder if the additives in those fuel system cleaners help make that alcohol compatible in gas engines. Plus, what if the alcohol is just an inert product and the 10% of the product is what does the cleaning? I'm not a chemical engineer but how do we know alcohol's what's cleaning these injectors anyway?
Old Oct 21, 2003 | 11:47 AM
Jack the Ripper
Banned
If you made a product that sold for $2-3 a bottle vs a product that did the same job that sold for $.98 a bottle would you tell anyone its the same thing?
Old Oct 21, 2003 | 11:50 AM
Jack the Ripper
Banned
1) From personal experiance and useage.
2) It helps break up the composits that build up.
3) it burns a little hotter and helps remover the deposits.
I amnot saying anyone HAS to do it this way. but it sure works the same if not better and alot cheaper.
Whatever floats your boat.
Old Oct 29, 2003 | 06:07 PM
accordi4's Avatar
accordi4
Any experiences on STP?
Old Oct 29, 2003 | 07:43 PM
EliteAccord's Avatar
EliteAccord
Banned
Stick with Valvoline SynPower Full Fuel System Cleaner
Old Oct 29, 2003 | 08:17 PM
uclaccord's Avatar
uclaccord
for 1-2 bucks more...i'm goin w/ the chevron stuff
Old Oct 29, 2003 | 11:10 PM
AccordDreamer's Avatar
AccordDreamer
Where exactly can I buy the Valvoline SynPower Full Fuel System Cleaner, and how much $$??
