does nose down help?
Old Oct 4, 2003 | 08:39 PM
97civic-vti's Avatar
97civic-vti
Default does nose down help?
can someone tell me if lifting ur rear wheels and lowering your front helps your car? i attached an image please give me technical detail regarding this setup. thanks!
File Type: jpg
Old Oct 4, 2003 | 08:44 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
Is your car a '69 Camaro or any other rear wheel drive musclecar of that era? It is only really beneficial to RWD. That guy probably has airbags or "switches". Don't be a ricer.
Old Oct 4, 2003 | 08:48 PM
97civic-vti
Default suspension
i asked my cousin and argued with him regarding this matter. i told him that the reason it is done to RWD cars is that when they press on the gas the rear goes down because of traction. he said that FWD (his civic) when he launches his front goes up.. weird.. thats why i want some technical information. im driving a 97 civic soon to be a vti.
Old Oct 4, 2003 | 08:52 PM
MPerson's Avatar
MPerson
All cars when they take off lean back, so if you had a REALLY fast civic, where your car goes down in the back a lot, then it's beneficial, but that's only for like 9 second cars.
Old Oct 4, 2003 | 08:55 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Actually there are 2 answers to this. If you do it some rigged way then no it will not help a bit. But on the other hand if you look at the pro import fwd drag cars they have wheelie bars on them but they do not keep the car from standing because it won`t cause its fwd, they have them set up with a c02 charge that when activated the bars press on the ground and raise the rear of the car up a little which in turn puts more pressure on the front and gives them better traction.
Old Oct 4, 2003 | 10:02 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
the process you are talking about is called "raking",..yes it benefits RWDs more,..but it can also benefit FWD cars also,...by lifting the back end and lowering the front end,..it somewhat puts more weight to the front wheels,...and if you have tractioin problems like wheel hopping,...more weight to the front can help reduce that
Old Oct 6, 2003 | 08:09 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
hmmm... I wonder if that would give me any more help at the track... h:
I may try this since I have c/os and can. We'll see what happens.
Old Oct 6, 2003 | 11:25 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Demon drop
I would say you will see little to no gain on a street car.
Old Oct 6, 2003 | 11:31 AM
oc_civic's Avatar
oc_civic
mcc racing
wouldn't stiffer rear springs help more.. wouldn't you want FWD to NOT squat back.. maybe raise it AND get stiffer springs
Old Oct 6, 2003 | 11:46 AM
illicon2003's Avatar
illicon2003
It's called "torque"..
