Cooling Fan
I just replaced both sensors on my g/f's 93 accord and all that was wrong was the t-stat was intermittantly stuck closed. It had the same systoms as a bad sensor though, no fan operation. if the t-stat stays closed the sensor behind the t stat never sees the hotter coolant and never tells the fan to come on. make sure the t stat is working right, its only like 15 dollars compared to 30-40 dollar sensors. The relays for both fans should be on the driver's side attached to the condensor fan shroud.
