Drag strip for the first time.. and my time!
Originally posted by Wharbone
I can picture you with a printed out version of this thread, and reading it at the line.
Yea the first time at the track it is ususally bad. Went I went with my 98 LS1 6 speed camaro I ran 14.2@104, only had the car fora week. Went back 1 month later ran 13.5 @106. The best I got in stock form with a tire was 13.2@107
I have no idea how to convert 1/8 times to 1/4 times, so I'm clueless :dunno:
I have no idea how to convert 1/8 times to 1/4 times, so I'm clueless :dunno: [/B][/QUOTE]
The best and most acurate way is to multiply your 1/8 time by 1.56 that will tell you close to what you will run in the 1/4.
Originally posted by lilbastrd
hey everyone.. i dont post much, just wanted to share my joy, well... i just got back from the track (irwindale drag strip)and got a time slip for the first time. I got a 97 GSR engine with the usual i/h/e and with stock tires, my best time was...
R/T - 1.041
60' - 2.508
330 - 6.590
1/8 - 9.916
Mph - 72.86
(dont know if thats good or bad.. hehe)
this place is only 1/8 of a mile long.. i know it sucks.. but hey.. its the closest one around.. wat u guys think my car would run on a 1/4?? i'm gona do some more mods before i'll head off to california raceway for the 1/4.. a bit of a drive.. gota make it worth it. thanks
R/T - 1.041
60' - 2.508
330 - 6.590
1/8 - 9.916
Mph - 72.86
decent i guess...what's your motor setup? It's weird cause a 2.5 60 foot is complete shit but your trap is only probably good for maybe a 9.8 anyways, so something isn't right.
I ran a 8.52 @ 80 last night with a 1.89 60 foot in my turbo 00 civic ex with the stock y8 motor @ 8 psi.
Aem cold air intake
Dc header
usdm itr exhaust with GSR muffler
thats all....
my tires is pretty bad.. couldnt grip at all.. spin like crazy.. i let go of the clutch at yellow.. when it hit green it was still spinning all the way up to 6 or 7 rpm.... btw i usually launch around 4-6 rpm, is that bad?? maybe i should launch at 3?
Dc header
thats all....
Aem cold air intake
Dc header
thats all....
Aem cold air intake
Dc header
thats all....
If you spin you need to lower your tire pressure to around 22 and try again if you still spin lower them again and after a few runs the tires will heat up and pressure will go up so check every 3 runs or so.
On i/h/e i would launch at least around 4500-5000 and don't dump it, let the clutch out till you grip and give it gas when you hook up then stomp the gas.
