header and cai?
Old Sep 7, 2003 | 11:30 AM
snatch's Avatar
snatch
Default header and cai?
im wrapping up my swap and im wondering what cold air to order, im swaping the 1st gen si-r into a 93dx so i was wondering which year should i order the cia for?
what i want is an aem cai with the bypass valve and a dc header,, also i was wondering who to go through to get them? who would you guys reccomend?
thanks in advance for the help
zach
Old Sep 7, 2003 | 12:05 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
If you're swapping an si-r engine into our car, the cai needs to be for the si-r. Same for the header. I would say go through Adventon.com for the header and Coximport.com for the AEM CAI.
Old Sep 7, 2003 | 12:11 PM
snatch's Avatar
snatch
ok so what years should i search for for the correct parts on those sites?
Old Sep 7, 2003 | 12:19 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
the CAI will not fit properly. you'll probably need the 92-95 intake but it will not fit up to the TB properly.
as for the header, you'll need the del sol DOHC VTEC header. that will probably not bolt on properly as you will need to either extend the piping or shorten it depending on how it sits now.
Old Sep 7, 2003 | 12:48 PM
snatch's Avatar
snatch
so what is your suggestion to do?
Old Sep 7, 2003 | 12:56 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
once you bolt on the header, go to your local exhaust shop and have them shorten/lengthen your exhaust (cat section) accordingly. I dunno about the cai tho.
Old Sep 8, 2003 | 07:25 PM
snatch's Avatar
snatch
i dont know how that will work since i have a test pipe instead of a cat, but ill see what i can do, im still not sure what im supposed to do for ordering the parts, does snyone know what year i should order stuff from to make it all fit right?
Old Sep 8, 2003 | 08:47 PM
snatch's Avatar
snatch
im looking at aem cai on ebay right now would the 92-95 intake work with the swap? or should i look for the 99-00 si intake?
Old Sep 8, 2003 | 08:53 PM
asiandoood's Avatar
asiandoood
like i said...the 92-95 CAI will work...it is where the intake meets the TB that will not bolt up. the AEM applications were made to fit US spec models...not JDM spec models where they had B16A civics. the 99-00 CAI will definately not fit correctly.
short rams will fit better in this case, unless you hacksaw the intake to make it fit.
Old Sep 8, 2003 | 08:54 PM
white_n_slow
it's my D in a B
well have them lengthen the test pipe then. For the header, it doesn't matter what year you get it for... any Bseries header will fit a B16. It might be easiest to order one for a 99-00 Si, but really it doesn't matter.
