Bump stop removal?
Old Sep 2, 2003 | 09:01 AM
DRTHV8R's Avatar
DRTHV8R
Default Bump stop removal?
I need to get the bump stops off my stock shocks to put on my AGX's. There seems to be a welded washer that keeps the bump stop from coming off. Do I need to cut it off? Any feed back would be great.
Old Sep 2, 2003 | 09:28 AM
agent87's Avatar
agent87
Need zzzzz's
If it's the thick washer I think you're talking about, it's not welded to the piston. You just need to give it a good whack to knock it off. Good luck.
Old Sep 2, 2003 | 10:06 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
:werd:
Old Sep 2, 2003 | 01:24 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
my suspension always needs a little encouragement (brute force) to come apart. Shouldn't be a problem.
Old Sep 2, 2003 | 03:49 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
ya knock it loose, think about it the suspension has to hold the weight of the car, its not gonna budge by hand. just whack it with a hammer or even a socket wrench.
Old Sep 3, 2003 | 12:21 AM
Toyz51's Avatar
Toyz51
Like they said, it is tapered so it is just wedged there. Just give it a tap with a hammer and it will break loose. Also, if you are going with lowering springs, you will want to cut the bump stops in half.
