Shocks n Springs....
Originally posted by angry sol
i think you have shocks and springs mixed up. the illuminas are adjustable shocks and progress springs are just that.. springs.
I had that same setup on my Civic (illuminas/skunk2's). I loved them, but they were harsh on my spine. Adjusting the height was easy cause the spring just sat there on the perch when jacked up.
The coilovers I have on my car now (tokico) are still compressed even when jacked all the way up and makes it hard to turn the thing. Plus side to that is it doesn't make noise when you go up driveways.
Handles awesome though, dude. Get them if you don't care too much about comfort.
Originally posted by Motohip
I had that same setup on my Civic (illuminas/skunk2's). I loved them, but they were harsh on my spine. Adjusting the height was easy cause the spring just sat there on the perch when jacked up. My coilovers now are still compressed even when jacked all the way up and makes it hard to turn the thing. Plus side to that is it doesn't make noise when you go up driveways.
Originally posted by Kai
Coilovers don't make the ride softer, that is all in the springs and shocks. If you want a softer ride, look into lower rate springs or coilovers with lower rate springs.
On a Del Sol, what is the maximum drop you can do without using a camber kit? Also, I'm looking into lowering the car with tokico shock/spring kit. I want it lower so it doesn't look so high, but I don't want to kill my body kit on every dip. What would be the best height adjustment? I was thinking 1.5"
