Turbo my crv/vtec motor...
I hae a crv/vtec motor in my 1992 Civic hatchback. Im looking for the perfect turbo setup for this hybridm otor. I was looking into the drag gen 3 kit. It includes everything I need for boost. My motor has a rebuilt had and I have a chipped ecu. What kind of boost can I handle? Any help would be great! Thank you. I will post a pic of my ride if you guys want.
i would recommend not having a vtec head on it when turboing it. but i wanna see pictures of it. if it's built right (the internals) you can handle some major boost.
Originally posted by Timmet93
My cr/vtec motor has a rebuilt head and stock bottem end. About 35,000 miles on the motor. I want to run about 8 psi. No more then that.
-T3/TO4E Turbonetics Turbo(I'm not sure what the Compressor maps are but I reached 7 psi at approx 3800 - 4100 rpms)
-B Series Turbo Perf. Nickel Plated Equal Length Tubular Steel Turbo Manifold with ext wastegate(Made for a 35mm wastegate)
-Custom Oil Pressure Restrictor for Turbo (To reduce the Oil Pressure to increase the Turbo life
-Greddy Large Front Mount Intercooler kit for the 92 - 01 Civic (Core Size 23.8" - 11.2" - 2.7", with 2.5" inlet/outlet)
-Greddy Oil Filter Sandwich (allows you to make multipe taps into the oil after it circulates through the filter)
-50 inches of -4 Oil Stainless Steel Braided Oil supply Line with anti-Rub fasteners
-Tial 40MM Wastegate
-Tial 40MM wastegate dumptube (to dump the exhaust fumes to the ground)
-Tial 50MM Blow off Valve
-Nickel plated piping for the Blow off Valve
-35mm - 40mm Wastegate Adapter to use the bigger Tial Wastegate
-2.5 inch Swooping Downpipe (for smooth flow)
-HKS Super Megaflow Intake (just changed the filter)
-The turbo intake has pretapped lines which allows you to easily install catch cans if you like.
-Pre Tapped Oil Pan for B series Engines
-16 T Bolt Clamps
-4 Regular Clamps
-All couples are Rubber Silicon 4 ply and Nitrile Elbos (black 90 bends)
-All the necessary plumping.
-All the oil return lines
What do you guys think about installing this onto my crv/vtec motor?
-16 T Bolt Clamps
-4 Regular Clamps
Sounds like a badass setup to me, equal length manifolds are badass. Have you checked out the precision turbos? They are basically a T60-1 with a T3 housing and they put out incredible numbers. My friend scott put down over 400 whp in his built GSR with their turbo.
That setup was on 1996 hatchbackwith a b16a. Would I have lots of problems installing this setup onto my car? Also I have a 255 lph fuel pump,fuel regulator and fuel rail. Would I need a FMU unit?
I would get a vafc or safcII for tuning it and have it dyno tuned. find a dyno w/wideband o2. if i was gonna run something as finicky as a cr/vtec turbo I would definitely want it tuned perfectly
