Supercharger Installed
Old Aug 28, 2003 | 03:48 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
Parasitic drag ring a bell? JRSC falls on its ass in the higher r's. I've driven both turbo and JRSC. I prefer turbo.
Old Aug 28, 2003 | 05:04 AM
jonjon's Avatar
jonjon
Yep, black civic with the tacky blue emblem in back.
Old Aug 28, 2003 | 06:08 AM
wilsel's Avatar
wilsel
Jackson Racing's website shows dyno results for a D16Z6 to be 142.5 HP, and 124 ft/lbs of torque. For $2495 I think I'd rather buy a low mileage B16, and have the same output.
Old Aug 28, 2003 | 06:20 AM
enginjim's Avatar
enginjim
Default turbo vs supercharger
All the supercharger guys keep talking about lag. Turbo lag was something that happened with turbos 20 years ago or if you chose a poorly matched turbo. I will admit if I am at 1500 rpm in 5th gear the jrsc will will have more power available, but that is why God put a shifter in the car.
The superior power output of the turbo is all a matter of efficiency. If both a turbo and a supercharged engine are making 7psi boost the cylinder produces a given amount of work. A portion of that work is goes to turning the crankshaft and the rest is rejected as heat and exhaust mass flow. All the power used to drive the supercharger comes from the crankshaft, robbing the engine of power output. The turbocharged engine for the most part uses the exhaust energy that is normally thrown overboard to drive the compressor. The crankshaft gets to give more power to the wheels.
Also good centrifugal blowers are more efficient than any of the rootes or screw type blowers. This results in lower intake manifold temperatures for the turbocharged engine which gives better power and is easier on the engine. Also installing an intercooler on a jrsc system is very difficult or impossible.
A supercharged system is also always limited by the fact that the output of the SC is fixed by being driven at a speed that is always proportional to the engine speed. So to get more boost you have to change pulleys? This especially bad with belt driven centrifugal SC's were boost is not linear to the driven speed. Those type of systems really have poor low speed performance.
For the turbo engine boost very easily adjustable and with electronic controllers a boost curve can be configured anyway you want it.
As four stroke engines technology continues everything will go to turbocharging and nothing will be supercharged.
Old Aug 28, 2003 | 08:28 AM
crucial Si's Avatar
crucial Si
Banned
Originally posted by igo4bmx
actually thining about it. you can run a JRSC with a 9 lbs pulley therefore giving u a constant 9 psi right?
imagine that vs a turbo at 9 psi... u miss all that pressure during lag.
aside frmo all the variables the JRSC has the edge
at 9 psi on a turbo car v a 9psi sc car, same motor same car, turbo will win every time.
Old Aug 28, 2003 | 08:36 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
i'd like a better understanding of that phenomenon, because i would think 9psi shows similiar air flow into the intake manifold, thus same amount of power (ecluding air fuel variables and the loss from increase mechanical pull on the crankshaft)
Old Aug 28, 2003 | 08:42 AM
crucial Si's Avatar
crucial Si
Banned
its not the same amount of power, turbos make better hp at higher boost
Old Aug 28, 2003 | 08:53 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
i understand what ur saying, but im trying to figure out why an engine that sees 9psi of pressure would have different HP numbers just based on how the 9psi was made?u know what i mean?
Old Aug 28, 2003 | 09:47 AM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
despite all this arguement, congrats on the install :yay:
i just love the louder spooling noise of a SC. besides the BOV, some of the turbo'd cars i sat in weren't as loud. :dunno:
Old Aug 28, 2003 | 09:58 AM
Pete97's Avatar
Pete97
Torque? In a civic?
Hm, only question I have is, is that JRSC gonna shake the shit out of your block? Thats what I've heard, but hey, I think both turbos and sc's are badass...
