Timing BElt
Old Aug 20, 2003 | 10:08 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
How much do you think it would cost to replace the belt and the waterpump?
Old Aug 21, 2003 | 06:20 AM
Jafro's Avatar
Jafro
I'm made of meat!
Most garages charge about $400 because it's labor intensive. A new engine costs a shload more than that if you're paying a mechanic to do the work, and that's what you'll need if it goes.
IF you know somebody that can do the work, you can get all the parts for under $150. You need a belt, water pump, tensioner pulley, and new accessory belts. You'd better pay that person for blowing up their day. It will no doubt take them a whole day to do it if they don't have all of the tools mechanics have.
Taking the upper timing cover off and inspecting the belt for cracks on several different spots is one way to check it. The other test should involve wiggling the belt. If it's loose and has more than an inch of deflection... you're playing with fire. It could jump and your pistons could shake hands with the valves...
Old Aug 21, 2003 | 06:55 AM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
Belt
Water Pump
Tensioner Pulley
Accessory belts
Is there anything else i am missing?
Old Aug 21, 2003 | 07:14 AM
Jafro's Avatar
Jafro
I'm made of meat!
1 bottle of antifreeze, RTV sealant, and maybe a new valve cover gasket if it's already messed up or leaking.
Old Aug 21, 2003 | 08:55 AM
FocuzDave's Avatar
FocuzDave
Member with a mega dong
Push down on your foot break all the way then give it gas and if its squealing and makin silly noises i think that means your timing is off....
Old Aug 21, 2003 | 03:40 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
OK
Belts
Tensioner Pulleys
Water Pump
Accesory Belts
Antifreeze
RTV sealant
Will this be all i need ? So we gotta flush the radiator to change the water pump right?
Old Aug 21, 2003 | 04:03 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
Originally posted by CiViC2nR86
OK
Belts
Tensioner Pulleys
Water Pump
Accesory Belts
Antifreeze
RTV sealant
yes sir.. don't forget your timing gun!!
good luck with it.. :thumbup:
Old Aug 21, 2003 | 04:25 PM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
If you are gonna do this yourself, I highly suggest using Moroso PN #61805. It makes life much easier when getting the crank pulley off.
Old Aug 21, 2003 | 08:23 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
I dont think i want to be doing this myself since honda engines are made to be "hitters" that means if the timing is off a lot the piston will as jafro said will "shake hands" with the intake valves.
