Brembo blank rotors
Old Aug 16, 2003 | 05:11 PM
CivicRacr's Avatar
CivicRacr
Originally posted by NeverBX
i doubt its even the rotors cause the way you describe the sound it sounds more like something is loose like maybe the retaining clips for the pads werent put in or you didnt secure them cause mine did that when i changed my pads. i had to squeeze a clip to make it fit snugger on the pad. might wanna check that out.
no, i've checked everything, took off the caliper, took of pads checked the pins to make sure they're not seized, then put everything back on and made sure everything was bolted on right. but this noise only started happening like a few days maybe a week after i finished the conversion.
EDIT: well i cant think of anything else to do but to take the brakes apart and check everything again. Thanks for all the help. :thumbup:
Old Aug 16, 2003 | 06:51 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
well the clicking sound could be your ABS dunno if coupes came with it standard but mine did, cause it pulses fast when you brake hard and once it slows down it gets slower. you might just need to bleed the system.
