doing my brakes
BOOM goes the dynamite!
i got some new rotors today, getting some aem pads soon. but i figured, while i'm at it, i might as well stick some stainless steel brake lines in there too. any reccommendations? also, how hard is it change all this stuff? i've never done any of it before. is there a write-up anywhere? anything else i should replace/upgrade while i'm there? i'm thinking of new brake fluid too (since i'm doing the lines). what should i get for that? thanks.
edit* and i have 4 wheel disc with ABS if that matters at all.
I'm getting new rotors, calipers and brake fluid too, maybe I should also do some new lines aswell. I didn't know how to do this 2 weeks ago, then I searched around here and Google and Askjeeves till I found all my info. Just make sure you bleed your brakes after your done. Including the Rear even if you're only doing the front!
