Nitrous Questions
Alright I am clueless when it comes to nitrous. I have a 1997 Ex 125hp with a CAI and exhaust system. Would it be safe to run 50 shot, and is that something I would just punch when I wanted to go fast or is that something that would be pumping all the time. Would I blow a head gasket (with 50 shot)? How fast do you all normally go through a tank and how do you replace that?
Thanks, I'm dumb.
Thanks, I'm dumb.
I have no N2O experience either, but I can answer a couple of those... Nitrous is something that you would only use when you want to go fast. Like, push the button and "Wheee!" How fast you go through a bottle depends on how often you spray and how big of a tank you have. The only places I've heard of that refill bottles are racetracks and some performance shops. Hope that helps a little.
h:
h:
i have been spraying my ex for two years strong.. 60 + bottles through the motor NO issues at all
yes you flick a switch
a typical bottle lasts like 3-4 minutes and the typical on juice part of a race is 12-13 secondsish
my local speed shop does fills
check this thread on some info about nitrous
click here
OC_Civic put some knowledge down on nitrous,..i did a little bit but i forgot all about the thread and didnt respond after awhile :doh:
click here
Generally, stock honda blocks will take up to 50% overall hp boost safely, whether it's nitrous or turbo. You can set a fuel controller to open it up at any % throttle. ex: full boost at 30% throttle. Most nitrous systems work with the push button, but all can be controlled by throttle with the right controller.
You might start at a 50 shot, but you probably could run 60 if your motor is in good health.
Originally posted by 165EJ1
50 shot is not worth $400+ to me, maby if you do 80 shot with dual fogger.:thumbup:
