still having problems changing my belts
Old Jul 27, 2003 | 07:57 PM
loctoday's Avatar
loctoday
Default still having problems changing my belts
aite guys, im still having a very hard time getting my belts off. i took the first belt off of my (98 civic ex) that was no problem, second one, the center bolt that adjusts the ac belt is rounded and i tried every possible thing i can think of. wd40 the clamps that lock nothing has worked. And also i got the two top bolts for my alternator to loosen up but the one in the bottom is also rounded. Any help is greatly appreciated thanks!!!
Old Jul 27, 2003 | 08:11 PM
dwnthehatch's Avatar
dwnthehatch
Try this
Craftsman Bolt-Out™ Damaged Bolt/Nut Remover Set
5 pc. set fits many popular sizes (metric/SAE) bolt heads and nuts. Spiral flute design grabs and removes rusted, painted over and rounded off nuts/bolts (fit may vary due to corrosion/damage/paint).
Bolt-0ut™ removers may fit many other applications other than those listed
Removers can be turned with a ratchet/socket or combination wrench, adj. wrench, pliers
Through-hole design allows removers to fit over longer studes and bolts
Tough, blow-molded case for convenient storage/room for 5 pc. add on set (52161)
#3 Bolt-Out™ remover fits Hex size 3/8 in.
#5 Bolt-Out™ Remover fits Hex sizes 7/16 in. and 11mm
#7 Bolt-Out™ remover fits Hex size 12mm
#9 Bolt-Out™ remover fits Hex sizes 9/16 in. and 14mm
#10 Bolt-Out™ remover fits Hex sizes 5/8 in and 16mm
Old Jul 28, 2003 | 09:44 AM
loctoday's Avatar
loctoday
no shit!!!thanx man i just went and bought it from sears..works like a charm i tried everything else nothing would get that biatch out. thanx again !!!
