EG Civic Diagnostic Question?
How do I diagnos an 94 EG Civic coupe? I know it rums on an OB-! system? Where is the diagnostic port and could I use the paper clip trick? and does anyboady know of what site where I can more info on this?
thanks
thanks
on the passenger side, uptowards teh upper right corner. there should be a green rubber harness pack. pull out the ecu jumper, its blue i believe then jump it with a paper clip, turn ur car to the position right before crankin, and count the check engine flashes for the code. try www.jdmfan.com
