rev limiter
Originally posted by reddemon009
i have a fully worked head valve springs, cam,port n polish,built bottom end je pistons eagle rods, running the greddy turbo kit 15 psi.
did you resleeve the block?
i bet your motor wont last a year.
did you guys read what i wrote.. i have the msd box with the rpm pill. i need to take out the stock rev limiter in the ecu so i can use the 8000 rpm pill thats in my msd box. so 8000 will be the new rev limiter.
I'm sure with a ported head, cam and better valvesprings he needs to rev higher. Plus he probably knows how his setup works better than anyone else. Plus his MSD ignition has a limiter anyway. I think you have to chip it but don't know where to get one from.
