where to mount my boost controller
Id either use the ashtray idea or you could always use some double sided tape and put it right above your right knee on the underside of the dash. Then use some wire loom to cover up all the wires and then run it under the dash.:dunno:
cx power!
Originally posted by westcoaststyle
Prolly too small... I'd put it above that, but I have my JDM coinholder there and I'm not cutting that up. :nono:
BAH! Gotta keep the JDM man.
Although, I do agree with you.
Don't know the exact dimensions, but it's really small. I'll see if I can find them online.
size: 3"W x 3"D x .75"H
Get some velcro strips and mount it to the mirror side if the sun visor, that way when you need it its right in front of your face and when you don't you can't even see it. This way there will be no cutting or drilling and if you don't like it there move it.
Sent you PM snake.
You guys have to realize that it's not just wiring that comes out of the back of this thing. I have to run a vacuum line too so mounting it on the visor won't work.
96: you have a 6th gen, the dash is very different. I wish I had the different areas that you do cause that would make it really easy to mount this thing....
