where to mount my boost controller
Originally posted by westcoaststyle
I have Hondata
h:
S200B :boink:
I have Hondata
h:S200B :boink:
I'm going with DSMlink on my drag car. Check it out if you're bored... www.dsmlink.com. Since my car's already got a EPROM ECU, it will cost me a lot less than it would most people.
If I ever bought a real motor for my civic, I'd go the same route you did.
:thumbup:
What about mounting it between the drivers seat and the center console. Convenient access to buttons.
Are you using it also as your boost gauge? You'll need to have boost visible when tuning, but when the car is running ok, you don't need to see it.
I liked the idea of having it mounted up by the sun visor. you could snake a vac line up the a-pillar...
good luck.
-PHiZ
good luck.
-PHiZ
I'm not taking any chances in pinching that vacuum line as it does basically have the power to blow my motor if it's not working correctly.
I'm pretty sold on the idea of mounting it in the glove box or under the dash somewhere and just get the remote switch. Oh, and no, I'm not using it as a gauge. I have one of those on the way.
