I busted a nut!! *pics*
Originally posted by Duff Man
cool...I was expecting bad comments
you 3 nut freak
Originally posted by Kai
Ideally you need a hydrolic press to do the job. It doesn't take too long either.
Originally posted by asiandoood
you 3 nut freak
you 3 nut freak
-Cheech Marin
I drove on 4 on one wheel in my supra the entire time I owned it- like 2 years. Its probably not as bad when youve got a 5-lug tho...
I stripped out one of those plastic washer/hub cap lugs from my '98 and drove around for about 4 months on 3. I torqued the rest tight with a torque wrench to 80 ft/lbs and never had a problem. I kept trying to find one of those nuts somewhere and finally stopped at the Honda garage for something else and bought one for like $3 (I though they'd charge like $20).
I think Honda's actually ride on the little ridge on the rotor/drum rather than actually putting the stress on the lugs. All they do is keep the wheel tight against the car, the weight is actually carried on that lip.
I change then on my Last car its not hard but they have to press the hub off but the bolt in and then u need a new wheel bearing . If u want i can scan the page out of my book. PM if u do
