compression and stuff
Does anyone know what the compression should be on a B16A with JE "Blower" pistons. This is in a 2000 civic si. All four cylinders are showing 125psi. This sees to be a bit low. The motor is not sleeved and has gapless rings in it. Any ideas?
-Chris
-Chris
Name stealer!!!
h:
Anyways, are you sure you are performing the test correctly? ECU fuse out, throttle held wide open? Gauge is tightened all the way down?
h:Anyways, are you sure you are performing the test correctly? ECU fuse out, throttle held wide open? Gauge is tightened all the way down?
Hold the throttle wide open, and do the test over.
