View Poll Results: Coilover Poll.....
Tokico Illumina R COILOVER
0%
TEIN TYPE FLEX COILOVER KIT
4
40.00%
TEIN SUPER STREET COILOVER KIT
3
30.00%
TANABE PRO S-0C COIL-OVER
10.00%
H&R COIL-OVER KIT
2
20.00%
Eibach Coilover PRO-STREET (in developement)
0%
Voters: 10. You may not vote on this poll
Coilover Poll......
Old Jul 12, 2003 | 12:40 PM
Tirod's Avatar
Tirod
Originally posted by westcoaststyle
PM me with your zip and item #s.
Best way to do it.
Tirod is happy so far.
:rockon:
Old Jul 12, 2003 | 12:42 PM
Tirod's Avatar
Tirod
the tein flex is a better system.. hence the higher price... its all about what you want them for... flex is for a little more serious racer than the SS and the SS over the basics... i've chosen the SS for that reason...
Old Jul 12, 2003 | 02:37 PM
92 GSR's Avatar
92 GSR
let me know if you want a good price on teins.
Bigup2neil@hotmail.com
Old Jul 12, 2003 | 02:51 PM
94civicEX's Avatar
94civicEX
I got worms.
I've heard a lot of good things about the Flexs. If you do decide to get them we get 5% off @ tornactive.com...they aren't badly priced. They also have the Tokico coilover for sale there as well.
99 Integra GSR
06 TSX
duck squad member #00003
Old Jul 12, 2003 | 03:30 PM
Tirod's Avatar
Tirod
it'll be hard to beat westcoaststyle's prices....
Old Jul 12, 2003 | 06:23 PM
qtiger's Avatar
qtiger
Originally posted by white94civic
I've got the Ground Control Special edition........They fit all shock combo's.....
For a better matching spring rate I should have gone with the Koni only Ground Controls....So the spring rate matched..........
Or do you think they will still out perform using this set?
The special editions are really, really soft. More for slamming the car on coilovers than anything else.
GC sells any spring rate you could possibly want. All you have to do is call and ask.
Originally posted by tirod˛slc
no they wont.... a full matched damper is better than any coilover/shock combo slop around setup out there.. street and track
There really isn't much difference if you use shocks with adjustable dampening.
Old Jul 12, 2003 | 06:26 PM
Tirod's Avatar
Tirod
sure there is.. even with gc mated with koni you have loose spring play in the rear when hitting a bump or what not.. when you lift the car the wheel drops and the spring is all loose.. with a damper such as tein.. it catches and the shock doesnt go all out leaving the spring /w play
Old Jul 12, 2003 | 09:11 PM
Johnny B's Avatar
Johnny B
Snap, Crackle, Pop....
I know that's totally what I wanted at the time...Cheap $300 adjustables..........I went as far as Tucking my Yokohama 195/45/15 tires.... ........(what a jackass right?)
Ended up blowing both front struts and having drive around the past week and need an emergency suspension change...(But no cash).......
You have to love credit cards........:naughty:
Old Jul 13, 2003 | 06:35 AM
qtiger's Avatar
qtiger
If you're hitting bumps large enough to let the spring drop you should be buying something intended for rally.
Old Jul 13, 2003 | 07:10 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
i've got custom spring rate ground control and koni's. great combination, but if you wanna go low and have stiff spring, you need to look into shortening and revalving the shocks for your spring rates.
Once I get my Koni's shortened and revalved for my spring rates, I couldn't think of anything more I'd want from my setup.
Truchoice also makes coilover kits using the Koni, GC method with custom spring rates and revalving already done. More money depending on what level you choose to go with.
Project EVA - The Track Package
Project EVA
