wheel hop
wow I was driving today and i was at a stoplight when a dx pulled up to me and revved, so i decided i might try to take him. Not hapenning I revved and when I let out the clutch my tires started to squeel and then the started hopping. I have never had problems with wheel hop before but this was bad what could be wrong?
shit I don't know man too much but I have never encountered wheelhop before... ya know that's a CX problem no tach just go by the ear and u get owned... it was probably my shocks it's gettin real bummpy lately
if youre getting ground controls, dont use youre stock shocks. They cant damp the increased spring rate, and it sounds like theyre probably blown or on the way out anyway. But seriously, you shouldnt upgrade your springs without upgrading your shocks. Handling and reliability will both suffer.
i was gonna but then i asked and looked around here and found out not too so now I gotta save up more cash for shocks but from what i've read it should be worth it... RIGHT?
wheel hop is an issue with fwd cars.
the springs and shock will def help
i've been working rather hard on reducing/removing wheel hop..
just got find a way to keep the weight down on the front and not let it shift towards the rear.
i've been doing polyurethane bushings, and motor mounts, and traction bars which greatly reduce wheel hop
nice sticky tires also help. there's lots of stuff you can do.
upgrade ur spring/shock combo and look into polyurethane motor inserts or mounts. you should ask bumnah if he has the short video clip of camera sittin on his dash while his car at idle with those mounts on. that will eliminate some hop for ya. :thumbup:
