Oil Filter?
Old Jul 11, 2002 | 04:32 AM
derf's Avatar
derf
Spec5
well, i haven't had a problem with fram. i guess i'll have to use up all the ones I bought. (my dad's car uses the same filter on his mitsub) thanks for the input guys.
Old Jul 11, 2002 | 04:50 AM
Guest
Guest
Posts: n/a
I used to use Mobil 1 oil and filters but the price was killing me because I change my oil so often. My new B16A is using fram filters and Castrol GTX every 2,000 miles. I use the fram because of the sure grip So, I should probably go with OEM then huh? You can get OEM filters by the case for fairly cheap. Thanks for the info, I had never heard anything bad about the Fram filters. What about bosch filters? Have you guys seen that you thing fram sells, it's a fitting that goes in the drain plug hole and it comes with a hose that attaches so you can direct the oil flow when you are changing it. I use it on my Maxima because the drain plug points towards the tire and it's a pain in teh ass to get my oil container under it. Also, it's windy as hell everytime I change my oil so the oil stream blows all over the place. does anyone else have that problem?
Old Jul 11, 2002 | 05:04 AM
derf's Avatar
derf
Spec5
i have seen it, don't use it cuz my civic's hold is directed towards the rear, not hard. and I change my oil in the garage
Old Jul 11, 2002 | 07:40 AM
P_S_Chang1's Avatar
P_S_Chang1
Check out these sites, which discuss the merits of various filters:
http://www.ntpog.org/reviews/filters/filters.shtml
http://www.frankhunt.com/FRANK/corve...ilfilters.html
Personally, I use OEM filters.
Old Jul 11, 2002 | 08:44 AM
crucial Si's Avatar
crucial Si
Banned
i use pureilator(sp? is total wrong but im lazy and dont care)
Old Jul 11, 2002 | 09:28 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
The 2nd one is it
Autocross Help Page
nonbox
Do It Yourself
2
Jan 2, 2005 11:56 PM
