dseries hatch header fit on a EX?
im not a noob by the way and thanks for your comment. i started my name over when the other site went down and i dont post much. the reason i was asking is because alot of b16 stuff doesnt work with a d16 and also some d16's do have different header setups but i wasnt sure which way it went.
Originally posted by crucial Si
if it starts w/ the same letter than it will fit.
not in all cases bub.
Originally posted by Jkan2001
you need to STFU, some people here are new and are learning. Even though you think that you are the s*it and have to go around the threads trashing people, i just want to let you know that no one gives a F*CK what you say. By the way you need to learn how to speak english...your sig says...I TORQUE MORE THAN AN SI, and who cares....the B16 doesn't put out much torque either. I suppose you "torque" more than my cl-s too
Cause it's DOHC and the D15 is SOHC. The ports don't line up when you try to swap the exhaust manifolds.... I believe the DOHC ports are slightly further apart. All you would really have to do to know if it would fit the head (not the cat) would be to get the exhaust manifold gasket for each and see if they are the same. If they are, it'll bolt to the head, if not... well there you go.
