*PiCs*my Si after the accident*PiCs*
1500. bomex is gone, only thing i still have to show for it is the wing. :wtc:
Originally posted by HatchVX
how much is it gonna to cost ya to fix it up?? Are u gonna to put ur bomex kit back on??? (i might be wrong about the kit name)
thats ryte! god damn dumb kids like me and..... YOU drivin fast on mountain passes. :chuckles:
Originally posted by DamnUndrSteer
Got damn dumb Kidz driving fast on Mountain passes. eheh, whuts up shingo...o_O
for the 92-95, u need to obtain the integra cluster harness and splice it into ur stock civic wires. for the 99-00 cluster, u do the same thing. what i seen ppl done on the teggy cluster is they swap the civic plastic cover over and use bondo to smooth it up and paint it blakk so it looks stock, im kewl with all that, i just trim mines good and reuse the teggy cover. now i just need a bezel and it would look good. follow this layout for a teg cluster in a 92-95 civic.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
on the teg right side plug for the fuel guage.. I had a pin in the 13 spot and had to move it to the 14 spot... other than that it was perfect....
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Originally posted by accord4thgen
Sorry to see the wreck pics....but least you are getting it fixed.
Have a question for ya though....what all needs to be done to get the GSR cluster to work and to fit in the 92-95 Civics? What years can you use and does the 99-00 SI cluster work? If you can give me the specs on all of that it would help out a lot.....thanks and good luck with your car man.
