How u remove back seat?
Old Jun 14, 2003 | 03:39 PM
Kabooki's Avatar
Kabooki
Default How u remove back seat?
93 honda civic sedan-
Just wonderin whats the trick to gettin the back seat out?
Im gonna run some wires straight back to the amp in the trunk, but the back seat has no obvious screws. Any tips?
It seems some loop is holding the front side of the bottom back seat part, but i cant find how to release the loop
Old Jun 14, 2003 | 03:46 PM
Mike99's Avatar
Mike99
U.S. CoastGuard
The bottom of the back seat has a forward facing loop of wire. You may be able to push it far enough back without taking the upper back seat off. On my 99 it's easier if you pop out the side plastic pieces to get it out.
Old Jun 14, 2003 | 09:45 PM
rexerin's Avatar
rexerin
beep! beep!
we took the back seat out of my 95 sedan and if i remember correctly, you have to fold down the back of the seat first, take that out, and then you can get to the screws for the bottom part of the seat.
we did it for the same reason... running amp and cd changer wires. i'll check with those who helped me do the install, but i'm pretty sure that's how we did it.
Old Jun 15, 2003 | 07:25 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
no... where the lower and upper seats meet, just off to the right from center, there's a 10mm bolt that you remove. When you've gotten that out, the back of the lower rear seat pulls up and forward. Be careful though, where you removed that bolt is a metal tab that juts out. Don't get it caught on the upper rear seat cause you could rip it.
Once you have the lower rear seat this far, it's easy to figure out.
HIH
Old Jun 15, 2003 | 09:10 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Why don't you lazy people just remove the upper rear seat first
Fold it down, remove the two bolts on each side. It will expose the bolt that Josh was talking about.
Old Jun 15, 2003 | 01:36 PM
westcoaststyle
I'm Josh BTW. h:
I've only taken my upper back seat out once and it was to get my old speaker box out...
Old Jun 15, 2003 | 01:42 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
there's easier ways to get that wire back there.
go along the side, fold down the seats, run the wire through the seatbelt, then under the hinge of the seat back. Push the wire out of site, and you're done.
Old Jun 15, 2003 | 03:54 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
or you could pull out the wire that's already going there (like to the rear seats....make sure you attach a rope or something to it so you can get it back) and then just attach the new wire to the old wire, pull the rope and get the wire back to the back. should work in theory atleast, right?
