Finally got my Si sway bar...!!
Originally posted by NeverBX
my ex does, my friends dx does and his brothers lx does.
as far as bushings rui,
i used the prothane ones, forget which ones but they are the size of a siver dollar and are about 1/2" thick, i got a gsr rear sway so i dont know if you need them. the gsr mounting plates are offset from the sub frame so you need bushings if you got a gsr mounting plate.
yours looks like its flat but its from the back view.
but it's all good.. gonna go with my buddy to hunt down a 240SX since he needs a car now.. so i guess this weekend will be alright.... but i wanna get my si bar on.... whinning whinning whinning... still stuck at work that's all...that reminds me... gotta get me a cusco rear tie bar... but most places are out of stock.
try ebay sometimes i see them on there. but rarely. as far as the bolts go, are you missing all the bolts or just the ones to mount the plates to the subframe? anyways when you put on the bolts/nuts make sure you get some lock washers for the bolts cause if you just put them on without them, after awhile the bolts will come loose. happened on my friends dx, he forgot to get some. i havent had to adjust mine since i put it on.
if you cant wait you can get some M8 bolts and nuts and lockwashers from your local hardware store as far as thread pattern it doesnt matter, i used 1.25, most places carry 1.5 but honda uses 1.25 threading. and about 1/2" long bolts.
