Need mechanical help!!!
Old May 23, 2005 | 03:24 PM
saltyf's Avatar
saltyf
I think the A/C clutch has failed on my 98 Civic EX. I've checked the system pressure, fuses and relays and it all seems to be fine. There is just no clicking sound when the AC clutch is supposed to engage. I even tried to hotwire the relay for it, still no sounds from the clutch.
Anyways, this is my first civic (just got it last week), and I was wondering if this is a common problem. And also if there is a way to replace the AC clutch without depressurizing the system and taking the entire compressor off. The space around the compressor seems awfuly tight, I can't even get my hand in there easily, not mentioning wrenches and pullers. Is there anithing I can take off easily to get access to that spot?
Old May 23, 2005 | 05:33 PM
eonsx311's Avatar
eonsx311
today is not my birthday.
Originally Posted by STOCK96civicDX
If you are in doubt of charging your system yourself (it is easy), take it to a shop. If you need extra info, PM me and i can give you a call and help you out.
talk about going the extra mile for a discussion forum. :bowdown: :bowdown:
Old May 23, 2005 | 09:17 PM
oscar_425's Avatar
oscar_425
Got V-TEC??
damn!!! very helpful info Stock96CivicDX!! you're teh man!
Old May 26, 2005 | 10:23 AM
saltyf's Avatar
saltyf
Heh, I figured out why there is no "click" sound when I turn the AC on. The AC clutch plate is MISSING!!!
Now I'm trying to find out if the compressor shaft broke off, or if this is just the center nut that got loose and caused the clutch plate to fall off.
Does anyone have an idea how far should A/C compressor shaft stick out from the pulley?
Old May 27, 2005 | 04:49 PM
hondacivic98ex's Avatar
hondacivic98ex
hi i have a similar problem...i checked the level for my ac and it was low so i went and bought a can and i charged it but now..its weird ...it keeps turning on and off and i was wondering where is that clip that you disconnect? i have a 98 civic ex...thanks
Old May 27, 2005 | 05:04 PM
hondacivic98ex
Old May 27, 2005 | 07:51 PM
FATHONDA's Avatar
FATHONDA
where does your tempature guage sit on a hot day of driving?
Old May 28, 2005 | 06:48 AM
hondacivic98ex
its normal...lil bit less than half..i checked the level of freon and it was low...the ac did blow cool air but not hella cold...my dad has a 96 civic and his ac blasts freezing cold...so i just added a can in and now, it turns on and off..but the level is normal..
Old May 28, 2005 | 08:22 PM
FATHONDA's Avatar
FATHONDA
it turns no and off? levels normal? what is the problem then?
Old May 30, 2005 | 05:02 PM
saltyf's Avatar
saltyf
The A/C pressure switch is on top of the reciever/dryer thing. But in oppinion it is easier and much safer to check the pressure with a pressure gauge. I think Walmart has them for <$10, and they also often come with refill kits.
